Using timer0 and serial interrupt in 8051
shaji001
Newbie level 2
Hi, I am implementing an up/down counter with a delay of 1sec(using Timer0) and dsiplaying it on the terminal using serial port at the same time. When i implement only the led display it works but when i add the logic for hyperterminal display it doesnt. But the same terminal display logic is working in a program where no timer interrupt is used. Can anyone please help me on this? Thanks.
May be the problem of Interrupt priority....
But can u put your code so we can varify it????
Hi, thanx for responding...I'm attaching my codehere. Please suggest any changes if required.
on the begin of interrupt subroutine is missing (minimum!):
"push psw"
end before instruction reti:
"pop psw"
