USING "TDA5051AT IC" ON THE 24V DC LINE
oyhan
Newbie level 3
Newbie level 3
tda5051at
HI
Do you know or Do you have scheme for DC Power Line?
Which Configration may I use on the DC Power Line.
Thnks..
dc power line communication ic
isolated may help you ,
hart modem transformer
I want to use TDA5051 Power Line Modem IC on the 24VDC Power Line and I need scheme for that? Thnks..
tda5051 dc line
i think same ckt will work for dc as well .
get a sample of tda5051
Dear Manish
I think you know this tda5051 IC. If you know that I think you can see some sample scheme in the Datasheet. Is circuits scheme same or not for AC and DCPower line?
Best Regards...
dc-lin schem
Hi
Yes , it can done but the design is a bit compliceted since you will need to use 2 DC isoleted transformer on each side
Also serch MAXIM site for HART modem ic - It is allmost the same but working over DC line (4-20mA)
All the best
Bobi
