Using SRAM as frame buffer in de2-115
hilal-t
Newbie level 3
Newbie level 3
Hello guys,
I have problem in using sram as frame buffer
I have tried the following code but i got random pixel where I expect to get black screen with one red dot in the center.
I write on sram at sync. time
code for writing and reading from SRAM
// SRAM_control
reg [19:0] addr_reg;
reg weSRAM;
reg [15:0] data_reg;
assign SRAM_ADDR = addr_reg;
assign SRAM_DQ   = (weSRAM)? 16'hzzzz : data_reg ;
assign SRAM_UB_N = 0;// hi byte select enabled
assign SRAM_LB_N = 0; // lo byte select enabled
assign SRAM_CE_N = 0;			  // chip is enabled
assign SRAM_WE_N = weSRAM;			  // write when ZERO
assign SRAM_OE_N = 0;			  //output enable is overidden by WE
assign mr={SRAM_DQ[15:12],6'b0};
assign mg={SRAM_DQ[11:8],6'b0};
assign mb={SRAM_DQ[7:4],6'b0};
wire reset;
assign reset=~KEY[0];
wire VGA_OK_TO_WRITE;
assign VGA_OK_TO_WRITE = (~VGA_VS | ~VGA_HS) & (~reset); //this will go high during blanking
always @(VGA_CTRL_CLK)
begin
if(reset)
begin
addr_reg<={Coord_X[9:0],Coord_Y[9:0]};
weSRAM <= 1'b0;
data_reg <= 16'b00000000000000000;
ledd<=1'b1;
 end
else begin
if (VGA_OK_TO_WRITE) begin
addr_reg={10'd3240,10'd240};
lock<=1'b1;
data_reg <= 16'b1111000000000000;
weSRAM <= 1'b0;
ledd<=1'b0;
end
else if (~ VGA_OK_TO_WRITE)
begin
weSRAM <= 1'b1;
lock<=1'b0;
end
end
end
 	VGA_Ctrl   u1	(	//	Host Side
						.iRed(mr),
						.iGreen(mg),
						.iBlue(mb),
						.oCurrent_X(Coord_X),
						.oCurrent_Y(Coord_Y),
						.oAddress(),
						.oRequest(SDRAM_READ_LOGIC),
						//	VGA Side
						.oVGA_R(oVGA_R),
						.oVGA_G(oVGA_G),
						.oVGA_B(oVGA_B),
						.oVGA_HS(VGA_HS),
						.oVGA_VS(VGA_VS),
						.oVGA_SYNC(VGA_SYNC_N),
						.oVGA_BLANK(VGA_BLANK_N),
						.oVGA_CLOCK(VGA_CLK),
						//	Control Signal
						.iCLK(VGA_CTRL_CLK),
						.iRST_N(DLY_RST_2)	);
I don't know what the point of posting a poorly commented out of context code snippet. Posts like this seldom get much attention from forum members, or answers. You don't explain if you simulated this or if you are one of those types that go right to the keyboard and start coding/synthesizing/programming_hw before you've even thought about how to design the circuit. I suspect you didn't do an up front design and/or a testbench.
From your code snippet, and the name of the singal(s) SRAM_WE_N, and weSRAM you're continuously writing to the SRAM while in reset. I suspect that isn't what you want to do.
I don't get why you would have the addr_reg assign a couple of signals and not a default of some sort. Seems like reset isn't actually a reset.
You also have no "reset" default for lock...is U (undefined okay (sim), or whatever the FF powers up to (hardware))
Thank you for reply.
I am newbie in FPGA, sorry for poorly commented code.
What I need is:
At sync time of the VGA I need to write the frame data to SRAM.
when VGA in displaying mode I need to read the stored buffer from SRAM.
at reset I want to clear the buffer in SRAM.
What I did is:
At sync mode of VGA I enable writing to SRAM.
At displaying mode I disable writing.
thanks a lot for your reply.
