Yes you can do this but the ISP needs to be sufficiently protected from the application circuitry. You can do this with a D-latch type chip or some other means of isolation.
You can also use diodes such as1N4148 to isolate ISP and circuitry, which is more cost effective and easier to handle when designing a PCB for your project.
