Using sensitivity analysis in CST
purushothaman
Newbie level 5
Newbie level 5
In reference to previous thread:
https://www.edaboard.com/threads/296190/
I, too, have the same issue. I am not getting any parameters listed in the dialog box. Did you solve the problem? If you have any document explaining the procedure to carry out sensitivity analysis, can you kindly share? Thanks.
You should look at the official CST document: "CST MICROWAVE STUDIO - Workflow and Solver Overview" that you can find it in installation directory or simply used the help. The sensitivity analysis is described on page 113. In short, you must define so-called constraints at first and then setup sensitivity analysis.
Good luck
