expert
Member level 2
send ir data using pic16f877
Currently i'm using a PIC16F877 to create a pulsing(eg : 10101010) which receive from keypad to the IR transmitter to be transmitted. i wish to use the feature from the PIC16F877 which is PWM to generate a carrier frequency 38KHZ to combine with my pulsing(10101010) to send the signal from IR transmiter to IR receiver 38KHZ. The attachment below is a simple coding to send data(10101010) without using PWM as output.SO CAN ANYONE HELP ME TO AMEND THE CODING IN ORDER TO OUPUT FROM THE PIN PWM IN PIC16F877 TO GENERATE A 38KHZ CARRIER FREQUENCY!!!!!!!!!!!!!
list p=16f877,f=inhX32, x=off
include <p16f877.inc>
__CONFIG _CP_OFF & _PWRTE_ON & _XT_OSC & _WDT_OFF
ERRORLEVEL -302 ;Suppress bank warning
TMRO EQU 1
STATUS EQU 3
PORTA EQU 5
PORTB EQU 6
TRISA EQU 85H
TRISB EQU 86H
OPTION_R EQU 81H
ZEROBIT EQU 2
COUNT EQU H'0C'
TEMP EQU H'0D'
ORG 0X00
GOTO START
;SUBROUTINE SECTION----------------
;2.5mS SECOND DELAY
DELAY1 CLRF TMR0
LOOPA MOVF TMR0,W
SUBLW .1
BTFSS STATUS,ZEROBIT
GOTO LOOPA
RETLW 0
;5mS SECOND DELAY------------------
DELAY2 CLRF TMR0
LOOPB MOVF TMR0,W
SUBLW .3
GOTO LOOPB
RETLW 0
;7.5mS SECOND DELAY-----------------
DELAY3 CLRF TMR0
LOOPC MOVF TMR0,W
SUBLW .6
GOTO LOOPC
RETLW 0
;CONFIGURATION SECTION--------------
START BSF STATUS,5
MOVLW B'00011110'
MOVWF TRISA
MOVLW B'00000000'
MOVWF TRISB
CLRF TRISC
MOVLW B'00000010'
MOVWF OPTION_R
BCF STATUS,5
CLRF PORTA
CLRF PORTB
;PROGRAM STARTS NOW-----------------
BEGIN BTFSC PORTA,0
GOTO BEGIN
MOVLW B'10101010'
MOVWF TEMP
BCF PORTB,1
CALL DELAY1
BSF PORTB,1
CALL DELAY3
TESTA0 BCF PORTB,1
CALL DELAY1
BTFSC TEMP,0
GOTO SETA0
GOTO CLRA0
SETA0 BSF PORTB,1
CALL DELAY2
GOTO TESTA1
CLRA0 BSF PORTB,1
CALL DELAY1
TESTA1 BCF PORTB,1
CALL DELAY1
BTFSC TEMP,1
GOTO SETA1
GOTO CLRA1
SETA1 BSF PORTB,1
CALL DELAY2
GOTO TESTA2
CLRA1 BSF PORTB,1
CALL DELAY1
TESTA2 BCF PORTB,1
CALL DELAY1
BTFSC TEMP,2
GOTO SETA2
GOTO CLRA2
SETA2 BSF PORTB,1
CALL DELAY2
GOTO TESTA3
CLRA2 BSF PORTB,1
CALL DELAY1
TESTA3 BCF PORTB,1
CALL DELAY1
BTFSC TEMP,3
GOTO SETA3
GOTO CLRA3
SETA3 BSF PORTB,1
CALL DELAY2
GOTO TESTA4
CLRA3 BSF PORTB,1
CALL DELAY1
TESTA4 BCF PORTB,1
CALL DELAY1
BTFSC TEMP,4
GOTO SETA4
GOTO CLRA4
SETA4 BSF PORTB,1
CALL DELAY2
GOTO TESTA5
CLRA4 BSF PORTB,1
CALL DELAY1
TESTA5 BCF PORTB,1
CALL DELAY1
BTFSC TEMP,5
GOTO SETA5
GOTO CLRA5
SETA5 BSF PORTB,1
CALL DELAY2
GOTO TESTA6
CLRA5 BSF PORTB,1
CALL DELAY1
TESTA6 BCF PORTB,1
CALL DELAY1
BTFSC TEMP,6
GOTO SETA6
GOTO CLRA6
SETA6 BSF PORTB,1
CALL DELAY2
GOTO TESTA7
CLRA6 BSF PORTB,1
CALL DELAY1
TESTA7 BCF PORTB,1
CALL DELAY1
BTFSC TEMP,7
GOTO SETA7
GOTO CLRA7
SETA7 BSF PORTB,1
CALL DELAY2
CLRF PORTB
GOTO BEGIN
CLRA7 BSF PORTB,1
CALL DELAY1
CLRF PORTB
GOTO BEGIN
END
TMRO EQU 1
STATUS EQU 3
PORTA EQU 5
PORTB EQU 6
TRISA EQU 85H
TRISB EQU 86H
OPTION_R EQU 81H
ZEROBIT EQU 2
COUNT EQU H'0C'
TEMP EQU H'0D'
ORG 0X00
GOTO START
;2.5mS SECOND DELAY
DELAY1 CLRF TMR0
LOOPA MOVF TMR0,W
SUBLW .1
GOTO LOOPA
RETLW 0
DELAY2 CLRF TMR0
LOOPB MOVF TMR0,W
SUBLW .3
GOTO LOOPB
RETLW 0
DELAY3 CLRF TMR0
LOOPC MOVF TMR0,W
SUBLW .6
GOTO LOOPC
RETLW 0
START BSF STATUS,5
MOVLW B'00011110'
MOVWF TRISA
MOVLW B'00000000'
MOVWF TRISB
CLRF TRISC
MOVLW B'00000010'
MOVWF OPTION_R
BCF STATUS,5
CLRF PORTA
CLRF PORTB
BEGIN BTFSC PORTA,0
GOTO BEGIN
MOVLW B'10101010'
MOVWF TEMP
BCF PORTB,1
CALL DELAY1
BSF PORTB,1
CALL DELAY3
TESTA0 BCF PORTB,1
CALL DELAY1
BTFSC TEMP,0
GOTO SETA0
GOTO CLRA0
SETA0 BSF PORTB,1
CALL DELAY2
GOTO TESTA1
CLRA0 BSF PORTB,1
CALL DELAY1
TESTA1 BCF PORTB,1
CALL DELAY1
BTFSC TEMP,1
GOTO SETA1
GOTO CLRA1
SETA1 BSF PORTB,1
CALL DELAY2
GOTO TESTA2
CLRA1 BSF PORTB,1
CALL DELAY1
TESTA2 BCF PORTB,1
CALL DELAY1
BTFSC TEMP,2
GOTO SETA2
GOTO CLRA2
SETA2 BSF PORTB,1
CALL DELAY2
GOTO TESTA3
CLRA2 BSF PORTB,1
CALL DELAY1
TESTA3 BCF PORTB,1
CALL DELAY1
BTFSC TEMP,3
GOTO SETA3
GOTO CLRA3
SETA3 BSF PORTB,1
CALL DELAY2
GOTO TESTA4
CLRA3 BSF PORTB,1
CALL DELAY1
TESTA4 BCF PORTB,1
CALL DELAY1
BTFSC TEMP,4
GOTO SETA4
GOTO CLRA4
SETA4 BSF PORTB,1
CALL DELAY2
GOTO TESTA5
CLRA4 BSF PORTB,1
CALL DELAY1
TESTA5 BCF PORTB,1
CALL DELAY1
BTFSC TEMP,5
GOTO SETA5
GOTO CLRA5
SETA5 BSF PORTB,1
CALL DELAY2
GOTO TESTA6
CLRA5 BSF PORTB,1
CALL DELAY1
TESTA6 BCF PORTB,1
CALL DELAY1
BTFSC TEMP,6
GOTO SETA6
GOTO CLRA6
SETA6 BSF PORTB,1
CALL DELAY2
GOTO TESTA7
CLRA6 BSF PORTB,1
CALL DELAY1
TESTA7 BCF PORTB,1
CALL DELAY1
BTFSC TEMP,7
GOTO SETA7
GOTO CLRA7
SETA7 BSF PORTB,1
CALL DELAY2
CLRF PORTB
GOTO BEGIN
CLRA7 BSF PORTB,1
CALL DELAY1
CLRF PORTB
GOTO BEGIN
END
