Using only a few particular cells while synthesizing using Design compiler
prabanjan1
Newbie level 2
Newbie level 2
Hi all
I want to get a gate level netlist which has only 2 input type gates. I do not want gates with fan in greater than 2. How do I get this type of netlist using design compiler?.
Thanks in advance
Create a list of all the gates which you don't want to use from your db. And set a dont_touch attribute on the list. DC will not use these cells for synthesis. All tech db's, I have worked on have the number of inputs in the name as a naming convention.
So I would suggest use the cell naming convention to your advantage and filter out a list of all cells which you want to use.
set cells_needed [get_lib_cells $target_library -filter (based on naming)]
set_dont_touch [remove_from_collection [get_cells *] $cells_needed]
These commands are built into DC using the variable set_target_library_subset
Hope it helps :thumbsup:
