Using marker in cadence
anhnha
Full Member level 6
Full Member level 6
In Cadence, for example, I plot Vout vs Vin of an buffer. And I want to use "Marker" to mark some points
in the curves, say Vin = 2V, 4V and 6V.
Is there a way that I can set up the marker so that when the simulation running is ended, the marks
will be marked automatically?
Thank you.
Why don't you use expressions for that? You'll get values of interest in output expressions window...
Thanks for the reply.
I want to save images for reference so I want to use marks automatically.
Hope there is a way to do that.
Then you can use Refresh function instead of replace, markers will update automatically.
