hamza1992
Newbie level 2
- Joined
- Aug 5, 2013
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 29
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 #include<avr/io.h> #include<avr/delay.h> #include<inttypes.h> #define rs PA0 #define rw PA1 #define en PA2 void lcd_init(); void ADC_init(); unsigned int ADC_read(unsigned char); void dis_cmd(char); void dis_data(char); void lcdcmd(char); void lcddata(char); int main(void) { DDRA=0xEF; ADC_init(); unsigned char data0[]="Temperatue="; unsigned char data1,adc_val; lcd_init(); LCD_print(data0); adc_val=ADC_read(3); data1=adc_val; LCD_print(data1); while(1); } void lcd_init() // Function for initialize { dis_cmd(0x02); // To initialize LCD in 4-bit mode. dis_cmd(0x28); // To initialize LCD in 2 lines, 5X7 dots in 4bit mode. dis_cmd(0x0F); // Blinking Cursor dis_cmd(0x06); // Entry mode dis_cmd(0x80); // This command gives the location of first letter ** 80 + 'x' ** shifts the display 'x' units right. _delay_ms(500); } void dis_cmd(char cmd_value) { char cmd_value1; cmd_value1 = cmd_value & 0xF0; // Mask lower nibble because PA4-PA7 pins are used (Extracting Upper Four bits) // Masking means clearing bits // Upper nibble is sent first and then the lower nibble lcdcmd(cmd_value1); // Send to LCD cmd_value1 = ((cmd_value<<4) & 0xF0); // Shift 4-bit and mask (Extracting Upper Four Bits) lcdcmd(cmd_value1); // Send to LCD } void dis_data(char data_value) { char data_value1; data_value1=data_value & 0xF0; lcddata(data_value1); data_value1=((data_value<<4)&0xF0); lcddata(data_value1); } void lcdcmd(char cmdout) { //Commands on LCD is initialized by having a negative transition on the enable pin. // 1) RS=RW=0 & EN=1; // 2) RS=RW=0 & EN=0; PORTA=cmdout; PORTA&=~(1<<rs); PORTA&=~(1<<rw); PORTA|=(1<<en); _delay_ms(1); PORTA&=~(1<<en); } void lcddata(char dataout) { //Letters on LCD is displayed by having a negative transition on the enable pin. // 1) RS=RW=1 & EN=1; // 2) RS=RW=1 & EN=0; PORTA=dataout; PORTA|=(1<<rs); PORTA&=~(1<<rw); PORTA|=(1<<en); _delay_ms(1); PORTA&=~(1<<en); } void ADC_init() { ADMUX=(1<<REFS0); ADCSRA=(1<ADEN)|(1<<ADPS2)|(1<<ADPS0); } unsigned int ADC_read(unsigned char ch) { ch= ch & 0b00000111; // channel must be b/w 0 to 7 ADMUX |= ch; // selecting channel ADCSRA|=(1<<ADSC); // start conversion while(!(ADCSRA & (1<<ADIF))); // waiting for ADIF, conversion complete ADCSRA|=(1<<ADIF); // clearing of ADIF, it is done by writing 1 to it return (ADC); } void LCD_print(char * str) { unsigned char i=0; while(str[i]!=0) { dis_data(str[i]); i++; } }
adc is not converting
i dont know the problem can anyone tell me what is the problem in my code.
