I am getting a 50bit signed number result from my multiplier. Now based on the sign bit my output would be classified either o or 1. I have written the verilog code as such but I am receiving such error. Could anyone guide me?
You want to put this into an always block, or just have an assignment with a ternary operator, or just assign class to the bit at index 49.
This is attempting to use the if-generate structure, which conditionally includes logic at synthesis time based on constant values. I didn't realize you could skip "generate" but Verilog is fairly relaxed on syntax rules.
When svm[49] is HIGH, then class has value 1b'1, else it has value 1b'0. As you have defined no sensitivity list so I would write it as...
assign class = (svm[49]) ? 1b'1 : 1b'0;
If you don't want to learn then birbal has your answer,
else
If you want to learn then know this
assign
Continuous assignments are the most basic assignment in dataflow modelling. Continuous assignments are used to model in combinational logic. It drives values into the nets.
In vhdl think of this as
Code VHDL - [expand]
-- a mux/switch
x <= a when b else c;-- constant assign
y <= consant
Whereas in Verilog
Code Verilog - [expand]
// mux or switchassign x = b ? a : c;// constant assignmentassign y = somevalue;
What you implemented was a sequential if, with combinatorial assign. In that method you'd need a
always@*beginif b==1 x = a;else x=c;//Verilog uses begin and end as c language { }end
VGoodtimes said as much, but he's such an expert that he uses expert speak - like ternary (? operations
