[SOLVED] using if command in hitec c
prasad70
Member level 3
Can some one please explain what is the wrong with below expressions.
if (( X1>9)&&(Y1>12)) RB0 =1
else
RB0 =0 ;
yes you have to make it like this
if (( X1>9)&&(Y1>12)) RB0 =1;
else
RB0 =0 ;
try it now it will work
ISMAIL
sorry . It was my typing mistake.
It doesnt work .
thk
no it doesnt work. Compiler doesn't give any error but i dont get any output.
below is my code.
unsigned char D1=0,D2=0,D3=0 ;
unsigned int RSL1=0 ,S2=0, RSL2 =9 ;
void main(void)
TRISB = 0x00 ;
for(;;)
	RSL1++ ;
	if (( RSL1 >5)&&(RSL2<9))    RB0=1;
	else
	RB0 =0 ;
	if (RSL1 >=9)  RSL1 =0 ;
You r making code for what elaborate completely...
Are you using any uC here or what???
I am using HI-TECH C® for PIC10/12/16.
I don't have any idea about PIC 10/12...
but the program is working fine..may be you are doing some sapling mistake in (TRISB or RB0) ...
void main(void)
TRISB = 0x00 ;
for(;;)
	RSL1++ ;
		RB0=1;
	else
		RB0 =0 ;
		if (RSL1 >=9)
			RSL1 =0 ;
Ismail
The code in post #5 and post #8 will keep RB0=0 constantly (because RSL2 = 9). Is this what you intend?
No. I intend to keep RB0 high only when predefined RSL2 < 9 and internal variable RSL1 >5 . During other ranges, RB0 should be low.
thks
I changed the code like below but still I dont see RB0 changes when program run.
unsigned int RSL1=0 , RSL2 =9 ;
void main(void)
TRISB = 0x00 ;
for(;;)
	RSL1++ ;
	if  (( RSL2 <5)&&(RSL1<8))
		  RB0=1;
	else
			RB0 =0 ;
	if (RSL1 >=9)
			 RSL1 =0 ;
How do you check RB0 state? It's supposed to change pretty fast.
I am using MPLAB SIM .
once i chnaged if (( RSL2 <5)&&(RSL1<8)) to if ( RSL2 <5 && RSL1<8) probelm dissapered. Now it's solved.
