Terminator3
Advanced Member level 3
Parallel quarterwave sections often used as DC block in microstrip circuits. This sections are always slightly thinner than 50 Ohm lines. How to design such coupling? I have read about microstrip bandpass filters and coupled lines (odd/even impedance, etc. https://www.microwaves101.com/encyclopedias/even-and-odd-mode-impedances). For filter Z0o and Z0e can be obtained from filter coefficients. But in this case all must be simpler. I think information from this link is enough, i just only to choose right "C = coupling in decibels". As i understand, C must be very small value, because C=30dB refers to weak coupling, while C=3dB is strong coupling. Knowing Z0o and Z0e it is possible to calculate line widths and gap, for example in QUCS line calculator menu. So how should i choose C value? Making it as small ass possible, or there is something else?
calculations in SpeqMath to check formulas from microwaves101.com example:
Also here we see wide sections between quarterwave parallel lines coupling:
![dc-block.png dc-block.png](https://www.edaboard.com/data/attachments/53/53159-38ac4ce68cbc2ca6cbb4850b4c13d681.jpg)
I think it is quarterwave transforming from 50 Ohm to something like 25 Ohm, maybe if coupled lines are too thin in 50 Ohm system.
C=3 'dB
C = 3
k=10^(-0.05*C)
k = 0.707945784
Z0=70.7
Z0 = 70.7
Z0e =Z0 * ((1 + k)/(1 - k))^0.5
Z0e = 170.971890725
Z0o=Z0 * ((1 - k)/(1 + k))^0.5
Z0o = 29.235741494
Z0 = ( Z0* Z0e )^0.5
Z0 = 109.944134333
