raman00084
Full Member level 6
in my project i am having 8 sensors. the sensors are placed 5 meters apart from the main pic control board. from the sensor to main pic control board i am using this LAN cable. for example if the first sensor is active it will send a logic 24 high through the lan cable this is receiver at the receiver side digital input board (opto-coupler-pc817) based then the signal is converted to 5v and fed to the pic controller io.
my dout is lan cables are ment for differential signal transmission because of twisting pair. in my project i am using the 4 twisted pair that is 8 wires for 8 digital input. can i use LAN cables it is correct? kindly help
regards
kalyan
regards
kalyan
