habibparacha
Junior Member level 2
Hi all,
I am trying to use the ADC of ATMega 328 using its ADC interrupt service routine but it is not working. When I use it without the ISR by just calling the ADC_read() function than it works fine but I have to use it by using the ADC interrupt. The problem is it doesn't even enter the ISR even the global interrupt is also set. I am using PORTB as an indicator whether it goes into particular code area or not.
Infact I am not able to get into any ISR not event the Timer0 Overflow.
Please help Its urgent.
#include <avr/io.h>
#include <inttypes.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#include <avr/sleep.h>
volatile uint8_t lower;
volatile uint8_t higher;
unsigned int ADC_read(unsigned char ch)
ch= ch & 0b00000111;
ADMUX=(1<<REFS0)|ch; // reading specified number of pin
ADCSRA|=(1<<ADSC);
while(!(ADCSRA & (1<<ADIF)));
ADCSRA|=(1<<ADIF);
//lower=ADCL; // ADC registor lower bits
//higher=ADCH; // ADC registor upper bits
//PORTB= ~PORTB;
void ADC_init(void)
ADMUX=(1<<REFS0);
ADCSRA=(1<<ADEN)|(1<<ADPS2)|(1<<ADPS1)|(1<<ADPS0)|(1<<ADIE);
sei();
ISR(ADC_vect)
PORTB=~PORTB;
lower = ADCL;
higher = ADCH;
int main(void)
DDRC=0x00; //initialize as input
DDRB=0xff;
DDRD=0xc2;
PORTB=0xff;
PORTD=0xff;
ADC_init();
while(1)
ADC_read(0);
