Using adc in pic18f452
Barasha
Member level 2
Member level 2
Guwahati ,India
Hello,
I am a beginner in mikroC. Need some explanation regarding 0x80 in the line shown below that are used in programs.
ADCON1 = 0x80; // Use AN0 and Vref=+5V
Read the datasheet ADC Section. ADCON1 is the register used to set which PORT pins to be used as analog input pins, in some uC to set Vref +/- voltages and to left or righ justify the ADC result. If ADCON1 is 0x80 then the 8th (0 to 7) bit (MSB) od ADCON1 is set which will be usually for left justify the ADC result which appears in ADRESH and ADRESL registers.
Hi salmanliaquat and jayanth.devarayanadurga
Thanks for the reply. Have seen the datasheet but still have a doubt about the data stored in ADRESH and ADRESL registers. Will the data stored be the digital value of the analog input.
