using 4 adc channel of xmega64 A3 microcontroller
skaddi
Newbie level 5
Hi all;
due to the point that xmega64 A3 has two ADC ( ADC A & ADC B) that each one has 4 channel;
I started to use 3 channel of ADC A.
but , the received data from third channel is always wrong. However the first & second one are true .
Now ,I really don't know what is the problem?
it is impossible tu guess what is wrong.
We need valid informations: Code and schematic.
* "is always wrong". What does that mean? ---> We need a much more detailed error description. Values...
Klaus
Reactions: skaddi
    skaddi
Klaus
you are right...
for more detail in continue I will put my schematic and the codes.
I want to read the VFB_BATTERY in third channel...
the codes for ADCA :
  adc_get_calibration_data(ADC_CAL_ADCA);
    adc_set_conversion_parameters(&adca_conf,ADC_SIGN_OFF,ADC_RES_12,ADC_REF_AREFA);
    adc_set_clock_rate(&adca_conf,125000UL);
    adc_set_conversion_trigger(&adca_conf,ADC_TRIG_FREERUN_SWEEP,3,0);
   // adc_set_config_compare_value(adcb_conf,KCK_MAX_CHARGE_AMP);
    adc_write_configuration(&ADCA,&adca_conf);
and the setting for each channel :
////for test by zahra  for motor 4 in channel 0
	adcch_read_configuration(&ADCA,1,&adca_ch_conf);
	adcch_set_input(&adca_ch_conf,ADCCH_POS_PIN6,ADCCH_NEG_NONE,ADC_CH_GAIN_1X_gc);
	//adcch_disable_interrupt(&adcb_ch_conf);
	adcch_write_configuration(&ADCA,1,&adca_ch_conf);
	//for test by zahra  for VFB_battery.. in channel 2
	adcch_read_configuration(&ADCA,3,&adca_ch_conf);
	adcch_set_input(&adca_ch_conf,ADCCH_POS_PIN3,ADCCH_NEG_NONE,ADC_CH_GAIN_1X_gc);
	adcch_write_configuration(&ADCA,3,&adca_ch_conf);
	/* Configure ADC channel 1:  motor3 current feedback
    * - Input: ADCB5
    * - Set Interrupt Mode: Below the threshold
    * - interrupts disable
    adcch_read_configuration(&ADCA,2, &adca_ch_conf);
    adcch_set_input(&adca_ch_conf,ADCCH_POS_PIN5,ADCCH_NEG_NONE,ADC_CH_GAIN_1X_gc);
	//adcch_set_interrupt_mode(&adcb_ch_conf,ADCCH_MODE_ABOVE);
	//adcch_enable_interrupt(&adcb_ch_conf);
    adcch_write_configuration(&ADCA,2,&adca_ch_conf);
    adc_enable(&ADCA);
    adc_start_conversion(&ADCA,ADC_CH0);
    adc_start_conversion(&ADCA,ADC_CH1);
    adc_start_conversion(&ADCA,ADC_CH2);
    //adc_start_conversion(&ADCA,ADC_CH3);
thanks for your attention...
This is neither a schematic nor an error description.
I'm out.
Good luck.
Klaus
