I have a problem with turning on the LEDS using push-buttons. The LED (1 or 2) only tuns on when I both push-buttons (long press pb1 , quick press pb2 to light LED 2 and long press pb2 , quick press pb1 to light LED 1).
The code is written in verilog.
Here is the Top level block:
module debouncer(
input [1:0]pb,
input clk,
output [1:0]score);
wire slow_clk;
wire Q1,Q2,Q2_bar;
reg [1:0]pb_out;
clock_div u1(clk,slow_clk);
my_dff d1(slow_clk, pb,Q1 );
my_dff2 e1(slow_clk, Q1,Q2 );
assign Q2_bar = ~Q2;
always @(pb)
begin
if (pb[0] == 1'b1) begin
pb_out[0] <= Q1 & Q2_bar;
end
else if (pb[1] == 1'b1) begin
pb_out[1] <= Q1 & Q2_bar;
end
else begin
pb_out = 0;
end
end
assign score = pb_out;
endmodule
module my_dff(
input DFF_CLOCK,
input [1:0]D,
output reg Q
always @ (posedge DFF_CLOCK)
begin
if (D[0] == 1'b1) begin
Q <= D[0];
end
else if (D[1] == 1'b1) begin
Q <= D[1];
end
else begin
Q <= 1'b0;
end
end
endmodule
module my_dff2(input DFF_CLOCK, D, output reg Q);
always @ (posedge DFF_CLOCK) begin
Q <= D;
end
endmodule
Test Bench waveform from fpga4student.com not working
Hi folks,
I tries to simulate the code and testbench from fpga4student.com and my waveform is not similar to the waveform given by the website, I don't know the problem. All the codes that I used is the same with what the website posted.
If you want the push buttons to independently turn on/off a corresponding LED, then why do you have the code to generate score (i.e. pb_out) in the same if-else if block and Q registers being shared between the two LED push button controls?
Inspecting you latest version of the code your implementation isn't a debounce it is more of a sampled input with an edge detect pulse output that sort of behaves like a debounce circuit under a limited set of conditions. An debounce circuit should reject all inputs that aren't stable for a given amount of time (usually in the 10s of milliseconds for switches) and passes the input to the output once the signal is stable for that amount of time.
