Use system generator to generate peripheral for EDK
Matrix_YL
Full Member level 1
system generator edk
hi all
I use system generator to generate HDL Netlist then use "Create and Import peripheral wizard" in XPS (EDK) to generate peripheral .
select "Import existing peripheral "
1.To an XPS project
2.Enter Name and Version
3.Indicate the Type of file …(I check"HDL Source Files"and"Netlist File"
4.HDL Source Files (I checked "Use an XST project file(*.prj))
but step 7 "SOPB:parameter" I meet a big problem I can't determine
base address and high address for my (system gen proj )which want to be peripheral
my questions is how to add base address and high address for my proj if it want to be used as peripherl for EDK
thanks in advance
create peripheral edk
I haven't used system generator to generate a peripheral for EDK before.
Try this method
Create a new peripheral in EDK.
Specify software registers,extra address lines, FIFO, interrupt, JTAG debug and a few others (Use the wizard). you can decide how you want to communicate to the peripheral but I usually use control registers.
This will produce opb_<name of peripheral>.vhd and user_logic.vhd. MPD will specify the parameters for the OPB bus, input and outputs for your component. You should instatiate your component in the user_logic and drive the signals out to the OPB<xx>.vhd. If you want to talk to the bus use the control you have selected in the wizard. You will also need to incorporate the netlist name in the pao file for compilation.
edk system generator
you means "create template for a new peripheral" and instantiate it in template ?
I think it maybe a good idea .thank you .
but is there have another to implement it ?
