Use a result from the previous time step at next time step. ADS transient simulation
junsik
Junior Member level 2
Hi im junsik.
I want to model arc resistance in the ADS simulation.
For that, I have to integrate the current from zero to at that time step.
As a result, I want to how use the result (current) from last time step in the next time step.
Is it possible to use the real time result during transient simulation??
Thank you.
Not in the same simulation, I think. Integration needs a measurement statement, and
computing the measurement results is based on postprocessing output.
So you can use the measurement result only in a following simulation, but probably in the same control file using the .alter command.
Reactions: junsik
    junsik
