bigdogguru
Administrator
- Joined
- Mar 12, 2010
- Messages
- 9,821
- Helped
- 2,350
- Reputation
- 4,694
- Reaction score
- 2,272
- Trophy points
- 1,413
- Location
- Southwest, USA
- Activity points
- 62,383
hi to all...
actually i checked the communication is taking place via the rs232 cable. For that i installed the vcp driver and tried to communicate using the hyper terminal . badly , it wasn't communicating. i gave the 16(trans) and 17(rec) pins to the rs232 cable's corresponding rec and trans pins... and ground to 5th pin. why it is not communicating ?
pls help
You can not connect the TX/RX pins of the FTDI chip directly to a RS-232 cable connected to a PC's RS-232 Port. You would need a MAXIM RS-232 transceiver device or equivalent, otherwise the FTDI chip could be easily damaged.
---------- Post added at 07:40 ---------- Previous post was at 07:29 ----------
RS-232 voltages levels can be in the +/- 15V range, which greatly exceeds your FT2232H devices +5v I/O pin tolerant rating.
