Usually, jumpers have to be placed to enable bus powered operation and set the logic supply voltage to either 3.3 or 5V.first i hav to go through the datasheet of the module
Are you referring to PIC24 programming? Yes, it will need a program. And you'll need some kind of programming adaptor (e.g. PICkit), if it's not already built-in to your development board, as it is e.g. with the Explorer 16.after installing the driver , should i burn the program
The suggestion was to access the module through Windows Hyperterminal or another serial application of your choice. No code is required for that, thus it's named virtual COM port.should i write the entire code for the module
