usb wifi receiver replacement
You can buy same frequency as your wifi receiver was operating. 2.4GHz was the frequency so try to find the receiver with same spec and sync it. But not sure whether it can able to match as the original one. But need to quite careful while selecting new one need to match all the specs as per your lost receiver.
Reactions: Dont
    Dont
If the suggest idea in the post 2 doesn't worked out means purchase a pair of Wifi transmitter and receiver with the same make and specifications. Replace with the old ones this will solve your problem.
Thanks for the answers!
I tried the a wifi receiver at the same frequency, but it does not detect the presenter. I guess there is some unique code. I'll try to find a pair of wifi transmitter and receiver.
