usb<-> rs485 <-> usb
nemuri
Newbie level 6
usb rs 485
hello everyone,
i am now working on a project where i need to do a kind of usb expender :
usb mouse connected on card 1 , then convert the signal to rs485 through a cat5 cable (100 meters) then convert to usb again and plug to the pc
i wanted to use the at89c5131 from atmel, but the problem is : i may loose the usb infos (i can only take the data, not the whole transmission)
does anyone know how to convert the usb signals directly to rs485 ?
Does anyone know a better solution ?
thanks a lot
unfortunately i think that won't work, because i need to re convert to usb signals at the end of the rs485 line. I need that because i'll connect a usb Hub at the end. So the tranciever will have to be transparent concerning the usb signals, hence no driver, no enumeration, no endpoint...
anyone knows about maxim's trancievers ? (like max3450e) I'm not sure what they're for.
Thanks a lot
Here is a less professional but effective method:
Go from USB to RS232 using a readymade card. Convert RS232 to rs485 and so the reverse job on the other end.
D.
