USB-RS 232 and hyperterminal
sana_akhtar
Member level 2
Member level 2
Hey
On the last part of project ... sigh
Using PIC16F877A, I used UART with PC and tried my code on proteus 8. Using virtual terminal on
proteus its working fine. Now when I linked it with PC through USB-Rs 232, installed successfully prolific driver and usb has been detected, it isnt giving anything on hyperTerminal. Even when HyperTerminal is giving the option of the port (COM4) on which USB has been connected. What is the possible problem here?
I tried FTDI driver, but it didnt work with this USB.
PA3040
Advanced Member level 3
Did you check loop back by connecting pin 3 and 4 pf DB9
Try with putty terminal software
hemnath
Chennai
In Device Manager, check the port number when usb is connected.
In hyperterminal, change the port number to as defined in device manager.
DB9 is a serial port connector which commonly used for serial port.
Best wishes :)
sana_akhtar
Member level 2
Member level 2
I did this before.. still not working.
Does hyper terminal support USB-RS 232 communication ?
I tried two other software, teraterm and putty. Both says that "unable to open port connection". So it means there is some connection problem. Where do I need to do settings, in code or in serial communication(PC) ?
FvM
Super Moderator
Staff member
Advanced Member level 7
Bochum, Germany
If you can't open virtual port COM4 in teraterm or putty, it won't open in Hyperterminal either. So something seems to be confused with your tests.
To check the virtual COM port function in your PC sytematically, you can:
- Unplug the USB adapter
- Open device manager and check that COM4 isn't assigned to a device
- Plug the USB adapter, the device manager should re-enumerate the devices and show the USB adapter as virtual COM port device
- Now you can connect to the virtual COM port, but onyl with one application at a time.
sana_akhtar
Member level 2
Member level 2
thanks. It has opened but showing nothing :/
WHYYYY????
here is the UART code I am using
/*  File:     UART.c
    Purpose:  To provide UART functionality for PIC uC
#include "Includes.h"
void InitUART(void)
	TRISC6 = 1;   					// TX Pin
	TRISC7 = 1;   					// RX Pin
	SPBRG = ((_XTAL_FREQ/16)/BAUDRATE) - 1;
	BRGH  = 1;                   	// Fast baudrate
	SYNC  = 0;						// Asynchronous
	SPEN  = 1;						// Enable serial port pins
	CREN  = 1;						// Enable reception
	SREN  = 0;						// No effect
	TXIE  = 0;						// Disable tx interrupts
	RCIE  = 1;						// Enable rx interrupts
	TX9   = 0;						// 8-bit transmission
	RX9   = 0;						// 8-bit reception
	TXEN  = 0;						// Reset transmitter
	TXEN  = 1;						// Enable the transmitter
void SendByteSerially(unsigned char Byte)  // Writes a character to the serial port
	while(!TXIF);  // wait for previous transmission to finish
	TXREG = Byte;
unsigned char ReceiveByteSerially(void)   // Reads a character from the serial port
	if(OERR) // If over run error, then reset the receiver
		CREN = 0;
		CREN = 1;
	while(!RCIF);  // Wait for transmission to receive
	return RCREG;
void SendStringSerially(const unsigned char* st)
	int i;
	for (i=0; st[i]!='\0';i++)
		while(!TXIF);
		SendByteSerially(st[i]);
#ifndef __UART_H
#define __UART_H
#ifndef _XTAL_FREQ
	#define _XTAL_FREQ   4000000  // Hz
#endif
// Comm Setup
#define BAUDRATE 9600  //bps
// 8 bit data mode with one stop bit
// No flow control, no parity bit
//Function Prototypes
void InitUART(void);
void SendByteSerially(unsigned char);
unsigned char ReceiveByteSerially(void);
void SendStringSerially(const unsigned char*);
#endif
sana_akhtar
Member level 2
Member level 2
here is all the code
#include <htc.h>
#include "uart.h"
#ifndef _XTAL_FREQ
#endif
void main(void)
	InitUART();
	while(1)
		SendStringSerially("hello world");
#ifndef __INCLUDES_H
#define __INCLUDES_H
// Define CPU Frequency
// This must be defined, if __delay_ms() or
// __delay_us() functions are used in the code
#include <htc.h>
#include "UART.h"
#include "ISR.h"
#endif
#ifndef __ISR_H
#define __ISR_H
void interrupt ISR(void);
#endif
sana_akhtar
Member level 2
Member level 2
didnt work :(
can this be because of time delay between controller and port ????
it just gave output once. I have written the output in while loop so it should have displayed it continuously. but it isnt.
paulfjujo
France 01800
hello
try before the basis , send charactere..
while(1)
 SendByteSerially('H');
 SendByteSerially('E');
 SendByteSerially('L');
 SendByteSerially('O');
 SendByteSerially(13);  // CR
 SendByteSerially(10);  // LF
 Delay_ms(500);
your code is working, tested on a terminal (19200 bds) via bluetooth link, but too much speedy
to see result on screen, add a delay and CR LF
void main(void)
    InitUART();
    while(1)
 Delay_ms(500);
El_Paco
Member level 1
Member level 1
Hi - i read your topic.
yes it can be because of time delay - usb fifo size...
First i would check if your connection is working from pc side.
Did you check loop back by connecting pin 2 and 3 at the profilic db9 connector.
If connection is stable to this point you should see the sign you typed in receive window.
The next point is to check if you have connected the PIC correct to the level converter and also the level converter correct to the RS232 Port ....
RX --> TX / TX --> RX
please post a schematic to see if the real wiring is correct.
if all this did not work --> throw away your profilic adapter and use a ftdi - do fine setting of fifo delay time in apapter / advanced setting ;-)
this joke has a real background - i had many trouble with differen hardware serial datalogger in conjunction with profilic...
the FTDI based adapter can be tuned really fine for your requrements, which is not possible with the profilic, i think.
some notes to your main.
Use a delay between every "Hello World" for test of 100ms.
Only for profilic topic to test
I think in your case it is hardware ( connection error) more than a profilic driver error.
If you have a scope then test:
the levels of the signals your level converter
Test if signals come in/out
Measure period time of the uart bit - to see if your baudrate setting is correct.
Check if this is the same as in your terminalprogram.
So i hope i can help you..
Best regards,
Paco
sana_akhtar
Member level 2
Member level 2
it works sometimes and sometimes not. Also when it works, it stop suddenly at different times.
I think there is some timing synchronization problem. When i disconnect hyper terminal and connect it after sometimes, it shows receive data. But when then stop at random times. If I disconnect for long time, it will show receive data for more time.
Now how to solve this? I inserted 100ms delay but of no use.
FvM
Super Moderator
Staff member
Bochum, Germany
Pull down UART lines of PIC using 10ks.
Which lines? logic-level UART is idling high, so it should be pulled up (if necesary). RS232 is idle low, but don't need pull-down resistors.
sana_akhtar
Member level 2
Member level 2
didnt worked ... it must be having some serious problem? some configuration error?Also I am using timer0 with external input. When timer0 get an input, UART stops receiving. Is there any link between this?
paulfjujo
France 01800
hello,
looka this **broken link removed** of using a USB-RS232 cable converter TREND TU-S9
RS232 level Output is on the DB9 (9 pins!) connector
and i a m using an adaptater to get pin 2,3,5 to connect to my UART PIC Tx,RX
and GND !!
i installed the corresponding Driver ( software part deliver with this product as a litle CD)
I can test the termina by shorting pin 2 and 3 ob DB9 connector
All i type on keyboard appears on display..( as echo)
it is the first step to do..
you must see, on your PC
peripheriques systemes
Port COM & LPT
Prolific USB-to-Serial com ( COMXX)
XX is the port number linked to USB -RS232
so, on your terminal, (i used Terminal VBRAY).
you must use COMxx ( COM5 in my case)
if it don't works .. go back
Solve this probleme before testing with your PIC..
