USB Port Over Current
arevindh
Junior Member level 1
Aluva, Kerala, India
I emergently need your help My system is showing :? on powering on **broken link removed** My battery charge is now only for 1 hour.
Two USB Ports are not working
No internal shortage of leads I think a leak in the IC .
Help meeeeeeeeeeeeeeeee :-:)-:)-:)-:)-:)-:)-:)-:)-:)-:)-:)-:)-:)-:)-:)-:)-:)-(
Don't you ? :oops::oops::oops::oops::oops::oops:
how did this problem start.. did it start all of a sudden or wht? try formatting ur system.
Probably a hardware chip has shorted or subjected to a high volatge surge due to thunder lightning or some other source. May be through the USB port, or may be through the LAN port or even may be through the power socket. Only way out is to remove the RAM's and see the performance with new RAM cards. If still the problem persists, the fault may be on the mother board.
Cheers
also chck the status of USB ports in the Device Manager..
probably there's sum problem with d motherboard.. get it checked wid sum hardware vendor
