[SOLVED] usart problem in atmega 8
vvarlord
Member level 4
Member level 4
i had worked with usart of atmega 8 for send and recieve data.
but after some days i have this problem which when i run a simple echo test for usart (recieve data by mcu and send it through com port again,and i use termite program for send and recieve),when i send a one digit number it works correct,,but with two digit number it gives garbage data
tnx in advance.
#include <mega16.h>
#include <stdio.h>
int a=0;
void main(void)
UCSRA=0x00;
UCSRB=0x18;
UCSRC=0x86;
UBRRH=0x00;
UBRRL=0x19;
while (1)
      scanf("%d",&a);
      printf("%d",a);
i don't think the problem is in codes
any suggestions?
i think the problem is inBaud Rate,You can double-check the baud rate of the PC and the microcontroller
the baud rate on both sides are set on 2400
could it be from a hardware problem?
