[ARM] usart interrupts in STM32F103VCT6
anju.m
Hi Everyone,
Iam doing a project using the STM32F103VCT6 microcontroller and the board used is HY-MiniSTM32V.The softwares used are STM32CubeMX(for generating c initialisation code) , Atollic TrueStudioLite (as the integrated development envirnment) ,Flash Loader Demonstrator(for flashing the code to the controller) and the Tera Term(for getting the output).I am currently doing usart interrupt program and i have my code along with this.The code works as follows: When I type "blink 1",it detects "1" and led blinks once and also if we type "blink 2",led blinks twice.And if we type anything else,the led will be on forever.But the program is not working as an interrupt can anyone suggest me how to fix this?Eagerly waiting for all your replies.
Anju
  • usart interrupt.txt
I can´t find an ISR.
all your code is driven with delay(), that needs 100% of processing power.
What do you want to work with interrupts?
Maybe I´m wrong, but I only see that it waites for "32" wich is " " = Space. But I dot see how t[0] can be "1", "2" ...
is '1' a string or an integer?
Post your code here. I have same board and same mcu and a lot of examples for it.
I want to make the whole program to work as an ISR.It waits for "space" and it displays whatever we write after the"space" ie if it is 1 or 2 after the "space",1 or 2 will be displayed on the screen and then the led will blink that number of times.Please suggest me how to make the whole prgm work as an ISR.
Anju
This is the code which I wrote.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
#include "stm32f1xx_hal.h"
#include <string.h>
#include <stdio.h>
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private variables ---------------------------------------------------------*/
UART_HandleTypeDef huart1;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
void Error_Handler(void);
static void MX_GPIO_Init(void);
static void MX_USART1_UART_Init(void);
char data1[20];
uint8_t time[3];
uint8_t i;
uint8_t t[6];
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration----------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* Configure the system clock */
  SystemClock_Config();
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_USART1_UART_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
 int flag=0;
 while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
      HAL_UART_Receive(&huart1,data1,20,1000);
 if(flag==0)
{ for(i=0;i<7;i++)
   {t[i]=data1[i];
     if(data1[i]==32)
       flag=1;
       int j=i+1;
   HAL_UART_Transmit(&huart1,time,3,1000);
  switch(t[0])
case 'b':     switch(time[0])
case '1':HAL_GPIO_WritePin(LED1_GPIO_Port,LED1_Pin,1);
         HAL_Delay(1000);
         HAL_GPIO_WritePin(LED1_GPIO_Port,LED1_Pin,0);
         break;
case '2':
         HAL_Delay(500);
         HAL_Delay(500);
         HAL_Delay(500);
         break;
case '3':
          HAL_Delay(100);
          HAL_Delay(100);
          HAL_Delay(100);
          HAL_Delay(100);
          HAL_Delay(100);
          break;
default: HAL_GPIO_TogglePin(LED1_GPIO_Port,LED1_Pin);
          break;
break;
default: HAL_UART_Transmit(&huart1,t,6,1000);
         break;
  /* USER CODE END 3 */
/** System Clock Configuration
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = 16;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
    Error_Handler();
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  /* SysTick_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
/* USART1 init function */
  huart1.Instance = USART1;
  huart1.Init.BaudRate = 115200;
  huart1.Init.WordLength = UART_WORDLENGTH_8B;
  huart1.Init.StopBits = UART_STOPBITS_1;
  huart1.Init.Parity = UART_PARITY_NONE;
  huart1.Init.Mode = UART_MODE_TX_RX;
  huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart1.Init.OverSampling = UART_OVERSAMPLING_16;
  if (HAL_UART_Init(&huart1) != HAL_OK)
    Error_Handler();
/** Configure pins as
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
  GPIO_InitTypeDef GPIO_InitStruct;
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOB_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(LED1_GPIO_Port, LED1_Pin, GPIO_PIN_RESET);
  /*Configure GPIO pin : LED1_Pin */
  GPIO_InitStruct.Pin = LED1_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(LED1_GPIO_Port, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @param  None
  * @retval None
  /* USER CODE BEGIN Error_Handler */
  /* User can add his own implementation to report the HAL error return state */
  while(1)
  /* USER CODE END Error_Handler */
#ifdef USE_FULL_ASSERT
   * @brief Reports the name of the source file and the source line number
   * where the assert_param error has occurred.
   * @param file: pointer to the source file name
   * @param line: assert_param error line source number
   * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
    ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE***
In my eyes this is the wrong order.
It´s like pressing "+", "2", "=", "5" when you want to calculate "2 + 5"
Usually the order is: "2", "+", "5", "="...where the "=" is the last input and starts the calculation.
* Either: First type a number then a [space] or [enter] (like on a calculator or a computer)
* or (don´t use [space] at all). Just wait for any input ... and if it is 1, or 2, or any other valid input, then perform an action. (only usefull for "one key inputs")
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
	GPIO_InitStruct.GPIO_Pin = GPIO_Pin_9;
	GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_PP;
	GPIO_InitStruct.GPIO_Speed = GPIO_Speed_2MHz;
	GPIO_Init(GPIOA, &GPIO_InitStruct);
	GPIO_InitStruct.GPIO_Pin = GPIO_Pin_10;
	GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IPU;
	USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
	NVIC_EnableIRQ(USART1_IRQn);
void USART1_IRQHandler (void)
	//your code here!
	USART1->SR &= ~USART_SR_RXNE;
And check that 'USART1_IRQHandler' called the same as you have in your startup.s file
Bad design decision.
Interrupts should be used for situations where you need to react quickly to some stimulus (e.g. a timer times out or a character is received). ISRs should execute quickly and let the rest of the program do the heavy lifting.
Susan
serial communication using usart
Hi Everyone,
Iam doing a project using the STM32F103VCT6 microcontroller and the board used is HY-MiniSTM32V.The softwares used are STM32CubeMX(for generating c initialisation code) , Atollic TrueStudioLite (as the integrated development envirnment) ,Flash Loader Demonstrator(for flashing the code to the controller) and the Tera Term(for getting the output).I am currently doing usart interrupt program and i have kept my code along with this.But the program is not working as an interrupt can anyone suggest me how to fix this?
CODE:
int main(void)
  HAL_Init();
  MX_GPIO_Init();
  /* Infinite loop */
  while (1)
	  uint8_t data[1];
	  //HAL_UART_IRQHandler(&huart1);
	      if(HAL_UART_Transmit_IT(&huart1,data,1)==0)
	             HAL_UART_Receive(&huart1,data,1,5000);
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
    Error_Handler();
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSE;
    Error_Handler();
    Error_Handler();
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
  * @param  None
  * @retval None
  while(1)
   * @retval None
#endif
insde stm32f1xx_it.c
#include "stm32f1xx.h"
#include "stm32f1xx_it.h"
uint8_t data[4];
/* External variables --------------------------------------------------------*/
extern UART_HandleTypeDef huart1;
/*            Cortex-M3 Processor Interruption and Exception Handlers         */
* @brief This function handles Non maskable interrupt.
void NMI_Handler(void)
  /* USER CODE BEGIN NonMaskableInt_IRQn 0 */
  /* USER CODE END NonMaskableInt_IRQn 0 */
  /* USER CODE BEGIN NonMaskableInt_IRQn 1 */
  /* USER CODE END NonMaskableInt_IRQn 1 */
* @brief This function handles Hard fault interrupt.
void HardFault_Handler(void)
  /* USER CODE BEGIN HardFault_IRQn 0 */
  /* USER CODE END HardFault_IRQn 0 */
  while (1)
  /* USER CODE BEGIN HardFault_IRQn 1 */
  /* USER CODE END HardFault_IRQn 1 */
* @brief This function handles Memory management fault.
void MemManage_Handler(void)
  /* USER CODE BEGIN MemoryManagement_IRQn 0 */
  /* USER CODE END MemoryManagement_IRQn 0 */
  while (1)
  /* USER CODE BEGIN MemoryManagement_IRQn 1 */
  /* USER CODE END MemoryManagement_IRQn 1 */
* @brief This function handles Prefetch fault, memory access fault.
void BusFault_Handler(void)
  /* USER CODE BEGIN BusFault_IRQn 0 */
  /* USER CODE END BusFault_IRQn 0 */
  while (1)
  /* USER CODE BEGIN BusFault_IRQn 1 */
  /* USER CODE END BusFault_IRQn 1 */
* @brief This function handles Undefined instruction or illegal state.
void UsageFault_Handler(void)
  /* USER CODE BEGIN UsageFault_IRQn 0 */
  /* USER CODE END UsageFault_IRQn 0 */
  while (1)
  /* USER CODE BEGIN UsageFault_IRQn 1 */
  /* USER CODE END UsageFault_IRQn 1 */
* @brief This function handles System service call via SWI instruction.
void SVC_Handler(void)
  /* USER CODE BEGIN SVCall_IRQn 0 */
  /* USER CODE END SVCall_IRQn 0 */
  /* USER CODE BEGIN SVCall_IRQn 1 */
  /* USER CODE END SVCall_IRQn 1 */
* @brief This function handles Debug monitor.
void DebugMon_Handler(void)
  /* USER CODE BEGIN DebugMonitor_IRQn 0 */
  /* USER CODE END DebugMonitor_IRQn 0 */
  /* USER CODE BEGIN DebugMonitor_IRQn 1 */
  /* USER CODE END DebugMonitor_IRQn 1 */
* @brief This function handles Pendable request for system service.
void PendSV_Handler(void)
  /* USER CODE BEGIN PendSV_IRQn 0 */
  /* USER CODE END PendSV_IRQn 0 */
  /* USER CODE BEGIN PendSV_IRQn 1 */
  /* USER CODE END PendSV_IRQn 1 */
* @brief This function handles System tick timer.
void SysTick_Handler(void)
  /* USER CODE BEGIN SysTick_IRQn 0 */
  /* USER CODE END SysTick_IRQn 0 */
  HAL_IncTick();
  HAL_SYSTICK_IRQHandler();
  /* USER CODE BEGIN SysTick_IRQn 1 */
  /* USER CODE END SysTick_IRQn 1 */
/* STM32F1xx Peripheral Interrupt Handlers                                    */
/* Add here the Interrupt Handlers for the used peripherals.                  */
/* For the available peripheral interrupt handler names,                      */
/* please refer to the startup file (startup_stm32f1xx.s).                    */
* @brief This function handles USART1 global interrupt.
void USART1_IRQHandler(void)
  /* USER CODE BEGIN USART1_IRQn 0 */
  /* USER CODE END USART1_IRQn 0 */
  /* USER CODE BEGIN USART1_IRQn 1 */
  /* USER CODE END USART1_IRQn 1 */
Re: serial communication using usart
Sorry for that.The code which I have attached now is a different one.
