ali shaheen
Junior Member level 1
- Joined
- Aug 29, 2010
- Messages
- 15
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- pakistan, karachi
- Activity points
- 1,419
hello
i had made the JDM programmer by my self,I got the schematic of that from the below given link.
I am using MPLAB for programming and PICpgm for burning the PIC18f452 microcontroller.
i am using 10mhz crystal osc with 22pf of parallel capacitors...a 5v power supply driven from a 9v battery and then lm7805....my basic code for only flashing the led from portB is given below
the problem I am getting is that the LEDs are not flashing as i want them to...instead they are not turning on either...from any of the ports....in configuration bits i had disabled watchdog timer,used HS osc type,.
please let me know what is the problem with it...either its the programmer or the code.......plaese please help me......am really in a hell lot of trouble.
best regards
ali shaheen
---------- Post added at 01:46 ---------- Previous post was at 01:45 ----------
---------- Post added at 01:51 ---------- Previous post was at 01:46 ----------
this is the link of the JDM programmer
[SIZE="2"];;SIMPLE led FLASHER
;;USING BIT SET AND BIT CLEAR ((BSF,,BCF)...
#INCLUDE<P18F452.INC>
ORG 100H
V1 EQU 25H;
V2 EQU 35H;
R2 EQU 15H;
R3 EQU 20H;
R4 EQU 22H;
LOOP
CLRF TRISB;
BSF PORTB,0;
CALL DELAY;
BSF PORTB,1;
CALL DELAY;
BSF PORTB,2;
CALL DELAY;
BSF PORTB,3;
CALL DELAY;
BSF PORTB,4;
CALL DELAY;
BSF PORTB,5;
CALL DELAY;
BSF PORTB,6;
CALL DELAY;
BCF PORTB,5
CALL DELAY;
BCF PORTB,4
CALL DELAY;
BCF PORTB,3
CALL DELAY;
BCF PORTB,2
CALL DELAY;
BCF PORTB,1
CALL DELAY;
BCF PORTB,0
CALL DELAY;
GOTO LOOP;
DELAY
;DELAY 20*100*250*5*400ns=1,000,000,000 ns = 1,000,000 us = 1s
MOVLW D'20';
MOVWF R4;
BACK MOVLW D'100';
MOVWF R3
AGAIN MOVLW D'250'
MOVWF R2
THERE NOP
NOP
DECF R2,F
BNZ THERE
DECF R3,F
BNZ AGAIN
DECF R4,F
BNZ BACK
RETURN
END [/SIZE]
best regards
ali shaheen
