Urgent Help Needed to fix asm code error
India, Kerala, Moolamattom
Thanks to all
Please Help me to fix an error in my asm code
Hope somebody help me
This is the code
#include <reg52.h>
#define ON 0
#define OFF 1
#define true 1;
#define false 0;
sbit LED = P1^0;
sbit sw =P3^0;
void Tmr0Init();
void Tmr0() interrupt 1
unsigned char cnt;
cnt++;
if(cnt==500) {
	LED = ~LED;
	cnt=0;
TH0 = 0xDC;
TL0 = 0x00;
void Tmr0Init(void)
TMOD=TMOD&0xF0;
TMOD=TMOD|0x01;
TH0 = 0xDC;
TL0 = 0x00;
ET0 = 1;
void main(void)
Tmr0Init();
EA = 1;
for(;;)
 if(sw == 0)
    k=debounce(50);
    if(k==0){
		LED=0;
		TR0 = 1;
   else{
		LED = 1;
int debounce(unsigned int a)
 unsigned int i,j;
 j=sw;
 for(i=0;i<=a;i++)
  for(i=0;i<=256;i++);
 if(sw == j)
  return true;
 else
  return false;
See the attachments
Thanks in advance
Manoj Soorya
I don't see a single line of assembly in your code, am I missing something.
You mention nothing of the error message you got or the line that has the problem.
One thing I notice is the use of a counter variable in the interrupt that is not static, that means the value is lost when you exit the handler.
In addition never use a local variable before initializing it, in your code below (assuming it was correct for this case) you will never know the initial value of cnt so don't assume 0.
unsigned char cnt;
    cnt++;
In order to preserve the value use
static unsigned char cnt=0;
    cnt++;
what compiler are you using ?
what is the error message ?
regards,
I am using keil for compiler
unsigned char cnt;
    cnt++;
    cnt++;
Actually the code written my friend. I am not know to write the programe. He elped me and now he was bussy. I am posting the hode here with his permission.
The code and the schematic not compatible....help me please sir.......
Thank you very much
