Depending on the referenced libraries, the "*" operator is only recognized for specific data types, e.g. signed, unsigned or integer.
The support for "/" operator is generally limited and vendor dependant.
Make sure that you dont use too many libraries. For example if you use numeric_std and std_logic_arith together in the same code, you may get errors since * is defined in both libraries and xilinx s/w will get confused.
There will be no confusion. numeric_std and std_logic_arith both declare signed and unsigned types, therefore these names and any functions on them become invisible to the compiler without specifying where objects/functions come from. This way there is never any confusion over which function you are using.
signal a, b : ieee.numerc_std.unsigned(7 downto 0);
signal c, d : ieee.std_logic_arith.unsigned(7 downto 0);
signal E : unsigned; --will throw an error because it doesnt know which unsigned to use
signal R1 : ieee.numeric_std.unsigned(15 downto 0);
signal R2 : ieee.std_logic_arith.unsigned(15 downto 0);
R1 <= a ieee.numeric_std.* b; --uses the numeric_std version of *
So the moral is - use one or the other, never both (numeric_std is recommended as it is a real standard, not a defacto standard. It has more functionality too)
thanks for all of you for the info...
bc initially i declared the signal as std_logic, so the Quatus II compiler nt accepted the '*' and '/' operations... Using unsigned declaration can solve the problem.
Hi FvM, about the '/' operation. what do you mean by limited or vendor specific?
i am using Quatus II for vhdl coding, is it supporting? i have checked the library inside my program, it has the operation...
Hi TrickyDicky and Vipinlal,
Thank for u mention on not using some many libraries, bc i still new to vhdl, so nt sure the use of library...
There is no '/' function inside the std_logic_arith/signed/unsigned package. You have to use the numeric_std package (given your response, I guess you are using), and used signed/unsigned types. Most synthesisors should now support the / function, and Quartus does (especially handy for doing bitshifts). I would avoid divides as much as possible though as they use a lot of logic on the chip.
There are several ways to avoid a divide:
1. If your inputs are small enough (like 8/9 bits in small FPGAs, you can probably get away with more bits in larger FPGAs.) use a look-up table instead. It gets your divide done in minimal logic and a small amount of memory, so you can probably run your clock faster than a normal divider.
2. Get a processor to do the divide for you and provide a 1/n value that you can put into a multiplier instead of a divide. This is not usually practical when both inputs change on every clock. This is best used for systems where 1 input changes infrequently (like filter co-efficients).
3. '/' is fine (and very useful) if you're simply doing bitshifts (ie. / 2^n). The compiler knows what you're doing and just drops the bits you dont need anymore (this is almost free in terms of logic).
