wp100
Advanced Member level 6
- Joined
- May 15, 2009
- Messages
- 3,051
- Helped
- 884
- Reputation
- 1,783
- Reaction score
- 733
- Trophy points
- 113
- Location
- Prime Meridian
- Activity points
- 0
Looking to provide backup power to a small aquarium, the average load would be 50w with a peak of 85w at 230v
Can readily buy some 480W UPS from the PC places relatively cheaply but they only use a 9ah battery so they would only give a 2hour backup at best.
Have seen some hack about adding a larger battery in parallel with the UPSs battery.
While I can see that would theoretically work, am a bit concerned about the safety in that from what I have read many of the parts used are designed to only handle full load for just a few minutes, so wonder if, even at a much lower wattage they will be ok for several hours ?
Perhaps just the addition of a cooling fan might be all thats needed at such a low wattage but having no practical experience of these UPS so do wonder if it will work reliably which is the most important factor.
Wonder if using a ready made 300w inverter that are used for long periods, eg in caravans etc, with a large battery and a diy switch over would be a better way ?
