[SOLVED] Update/ Replace Components location shifting issue in Eagle version 9
Prabhakarankft
Member level 3
Chennai, India
Hello Everyone...
I am using Auto desk Eagle version 9 for PCB design. More than 2 years I am using the same for my project works. My current version in Eagle 9.0..
Due to some reasons I need to update all My resistors(Pads size- Landing Area) and capacitors in all my work which was done previously. It will be more than 25 boards!
I have Edited the pad size in my rcl.lbr. Same Library was used to design that board before some years. I have clicked "Update all" option from the library menu.. I was expected just Pad size only will be change in that board.. But location of the every resistor and components are changed. It is looking like a fresh board..
Since it is finished board I don't like to re-route and re- placement.. Kindly suggest what to do??? I need just to change size of PAD in all resistor & Cap..
I am facing this issue only in this version. In previous version of Eagle it was perfect.
