Error:Info: Command: quartus_map magi_fw --rev=magi_fw --family="MAX 10" --part=10M25DAF484I7G
Error:Warning (18236): Number of processors has not been specified which may cause overloading on shared machines. Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance.
Error:Info (20030): Parallel compilation is enabled and will use 2 of the 2 processors detected
Error:Error (12007): Top-level design entity "magi_fw" is undefined
Error:Error: Quartus Prime Analysis & Synthesis was unsuccessful. 1 error, 1 warning
Error: Error: Peak virtual memory: 566 megabytes
Error: Error: Processing ended: Tue Oct 15 20:55:08 2019
Error: Error: Elapsed time: 00:00:11
Error: Error: Total CPU time (on all processors): 00:00:01
Error:child process exited abnormally
Error: while executing
Error:"exec quartus_map $project_name --rev=$project_name --family=$family --part=$device"
Error: (procedure "tdc_mif_update" line 8)
Error: invoked from within
Error:"tdc_mif_update"
