upcounter and updown counter power and area
tv123
Junior Member level 3
Will there is be power and area difference for an 6 bit upcounter and 6 bit updown counter?
Probably. Why not build them and find out.
Reactions: tv123
    tv123
I'd expect that a 6-bit updown counter will take at least as much power/area as 6-bit upcounter, and possibly a bit more. I'd expect area increase to be slightly more pronounced than power increase. But as TrickyDicky said, try and find out for yourself. :)
Is there a possibility of replacing a up/down based frequency divider by a upcounter one with a rst signal
i.e, if a max count is given and an updown counter counts two and fro to max and to zero with a high frequency signal.
Instead of this can i use an up counter which counts to max and then rst and again count to max and so on.
If rqrd i can give more explanation
If you are in an FPGA - you should not be using any sort of counters for frequncy division, unless you are generating a clock enable. Creating new clocks should be done as the output of an MMCM or PLL
