santais
Junior Member level 1
So I'm currently trying to build a circuit, where you basicly have a counter which counts up or down and shows it on a 7 segment display.
Quite simple so far.
It has to be able to count from the range 0-999, but again that is just 3 counters, with following 3 decoders. Anyway my questions are:
Do you guys know any common up/down counter with 2 clocks? The main idea is, that you have 2 buttons, one button which counts up and the other which counts down. I've been trying with a 4510, but you can only use one switch to count with, and the other switch to change the U/P input from low to high. So that's not going to work. Been looking for some time, but just can't seem to find any setup with those, who has two clocks. I.e. then I found a 74193, but just can't find any setup to it (Very new to electronics).
Secondly, I only want to count up the even numbers, 2,4,6,8.. and so on. How do I make the conter count twice, everytime it receives a pulse? Really really lost on this part
