Unleash the Power of RK3588: The Game-Changing Processor for ARM-based PCs and Edge Computing
Forlinx
Banned
Member level 2
Are you looking for a low-power, high-performance processor for your ARM-based PC or Edge Computing device? Look no further than the Rockchip RK3588 SoM.
1699077867316
Forlinx RK3588 Single Board Computer
Featuring quad-core Cortex-A76 and quad-core Cortex-A55 processors with separate NEON coprocessors, the RK3588 supports 8K video codec and boasts many powerful embedded hardware engines that provide optimized performance for high-end applications. With its rich functional interfaces, it can meet the product customization needs of different industries.
1699077708896
The RK3588 has a highly integrated SoC design, which can effectively reduce the cost of the whole product. It also features an embedded 3D GPU ARM Mali G610 that is completely compatible with OpenGLES 1.1, 2.0, and 3.2, OpenCL up to 2.2, and Vulkan1.2. The special 2D hardware engine with MMU maximizes display performance and provides very smooth operation.
In addition to its impressive processing power, the RK3588 introduces a new generation of totally hardware-based maximum 48-megapixel ISP (image signal processor). It implements a lot of algorithm accelerators, such as HDR, 3A, LSC, 3DNR, 2DNR, sharpening, dehaze, fisheye correction, gamma correction and so on.
The built-in NPU supports INT4/INT8/INT16/FP16 hybrid operation, with computing power up to 6TOPs. With its strong compatibility, network models based on a series of frameworks such as TensorFlow/MXNet/PyTorch/Caffe can be easily converted.
1699077780530
The RK3588 has a high-performance quad-channel external memory interface (LPDDR4/LPDDR4X/LPDDR5) capable of sustaining demanding memory bandwidths. It also provides a complete set of peripheral interfaces to support very flexible applications.
Don't miss out on the game-changing power of the RK3588 System on Module. Upgrade your ARM-based PC or Edge Computing device today and unlock its full potential.
Learn More:
https://www.forlinx.net/product/rk3588-som-134.html
Official website:
