shoaibali
Member level 1
unidirectional buffer
Hi
I am using an external Crystal to supply clock to PIC microcontroller and am using XTAL out(12MHz) of microcontroller as an input clock of an other microcontroller and everything works fine.
Problem starts when the second microcontroller is plugged in/out (of the Zif socket) while the 1st microntroller is operational, causing disturbance in Xtal circuit and so the first microcntroller resets/hangs.
I want to find a way so that I can use the same Clkout of 1st microcontroller as input clk for 2nd one but instead of connecting directly I am thinking of putting a Analog mux/switch/buffer so that the input of that Analog swithc/mux/buffer is not disturbed by its output (which will be connected to Clk in of 2nd microcontroller). So, far I am unable to find a unidirectional analog buffer/switch/mux.
Any ideas/suggesion well appreciated
Regards
Hi
Regards
