unidentified transistor....please help
ghettoman
Full Member level 1
romania
c1740 transistor
loks like is produced by st ?
st c1740 ---maybe an bc174?
st a933 ---don`t know
anyone heard about these transistors?the web is dead in this problem :(
please help
a933 transistor
Hello
I guess you must look for :
2SC1740 and 2SA933
Regards
transistor a933
If it is working you could do some measurements on it by finding the pinout with a multimeter and then measuring the beta by putting the base to a voltage through a resistor and then the collector to the votlage throuigh a current meter. usually low beta transistors are higher frequency than high beta ones. From these clues you could pick out a replacement.
1amn transistor
THE TWO TRANSITORS ARE PATERN COPIES OF NEC 2SC DEVICE
AS MENTIONED ABOVE
THEY ARE INFACT GENERAL PURPOSE PNP AND NPN DEVICE
BUT NOT A MATCHED PAIR
2SA933 is a common device in amplifiers and general switching situations in shit eastern plastic junk crap self destructing
badly designed hifi and houshold rubbish
the second device is a well known audio amp or general purpose amp
from the same genoration of said
i would recomend using a 2sc 1815 and 2sa 733 to replace these
as the 933 is far worse than the 733
the gp amp 2sc device
can be replaced hahaha by just about any npn or in most cases 2 diodes and a zener made into a transistor
but an 1815 is the best
and at 10 euro per 100 parts is dam cheep
1815 transistor
How about 1AMN and AP17 this two transistor ? Could someone give me the manufactor name and part number ? Thanks
