What is the solution to read data from max232 board which is used to communicate between two control boards? I am using this max232 for communication between vending machine's control board and raspberry pi 3. I want to read the data that what exact command/data receive from the vending machines's control board?
There is no such data in their datasheet that how will I read the MAX232 Board.
When I tried to read through the converter cable then MAX232 has stopped working with the vending machine.
Are you aware that we don´t know which vending machine you are talking about, which "MAX232 board" you use, wich converter cable you use, what software you use, what port setup you use?
