Unable to find "Create Far Field reprot" under HFSS -> results
1983.mon
hi,
I am using HFSS V.11.
In order to generate out the S-parameters, gain and VSWR, I was unable to find "Create Far field report" under
HFSS-> results as attached picture. any idea ? Did I miss out any steps ? I had done solution Data steps and Analyze all after I have drawn my design. Please advise. Thank you.
Mon
Re: Unable to fund "Create Far Field reprot" under HFSS -> results
try to create radiation boundary first.
Hi..
I have done that. Please refer to the attached picture.
need your advise.
as i can see that there is a radiation boundary created but no radiation setup defined! look for the project manager tree, there you shall find a radiation (setup). In the pic above look for the same in the left side of the screen. Right click on the same and define the radiation setup, theta and phi range for the radiations calculations and least count for the same. Then after you analyze all, far field results would come as an option under results header.
