Ultra low leakage analog switch?
Astrid
Full Member level 3
Full Member level 3
Hello,
There is a semiconductor analog switch, which should off leakage current in order pA (1-5pA) ?
I need to switch resistors for current measurements in the order of nA to pA
Better use reed relays for such low leakage figures.
you are right, but the size and especially speed is significantly worse at relays.
I have 7 resistors for current range 10mA - 10nA
The problem is in the lower range
- 100pA - 10nA
- 10nA - 100nA
- 100nA- 1uA
For the pA range will use latching relay, but for higher range used semiconductor switch.
