ULN2003 and 12V DC Relay clarrification.
Titus Manoj Kumar
Junior Member level 2
Sriperumpudur, Tamil Nadu
Hi.,
Am working on 12V relays and ULN 2003 using ATMega16.
The simulated model attached.
Is this schematic correct?
Relay is switched in the simulation but not in hardware.
Output (1C) pin of ULN2003 is not varying, it is constant 12 V.
Note: Power supply given to the relay 12V DC 0.5 Amps.
What's the error? What should I do to fix it?
Please do help.
Thank you.
Hi Murali_dece,
Here is the image.,
https://obrazki.elektroda.pl/5747388000_1394892247.png
Yes I did connected the 8th pin of ULN2003 to negative of 12V.
Hi BenJons01,
Am using it for switching the cylinders in Injection Molding Machine.
My project is automating the semi-automatic injection molding machine.
I'l have a 12V DC solenoid switch & using a 12V relay(which is basically a switch) can control it.
It's not advisable to connect a relay straight to a microcontroller so we're going for ULN 2003 IC which is a relay driver IC.
http://obrazki.elektroda.pl/5747388000_1394892247.png
you have to confirm the operation of both uln2003 and micro controller. isolate the pin-1 of 2003 and apply 5v directly to check its operation. if its operation is fine you have to check the Mc output port configuration
