MicroWelding Services
Good Evening my name is Milos Michael Jevtic from Micro Welding Services
We have a project that we require some help with a development for a prototype device for our customer we require a 4G UHF frequency chip that is dual band and can send/receive data also GPS locations I Have attached a spec sheet with an overview of the chips requested functions the chip will be a triode that is used for high frequency local vibration and mixing the chip will also be used for rectification switching and limiting.
ULTRA HIGH FREQUENCY PNP TRANSISTOR CHIP TECHNICAL REQUIREMENTS
Chip Size: 0.32x0.32mm
Chip Thickness: 200μm~240μm
Packaging Method: Box Packaging
Electrical Parameter Requirements
Parameter Symbol Test Conditions Requirements Units
Other Requirements
Function detail:
The Chip function will be for sending and receiving of date rectification switching limiting the chip is used as a Triode it will be used in a high frequency 4G signal sending and receiving as well as a GPS chip high frequency local vibration and mixing.
Parameter | Symbol | Rated Value | Units | Measured in |
Power | Ptot | -- | 0.225 | W |
Collector Current | Icm | -- | 50 | mA |
Maximum Junction temp | Tjm | -- | +175 | ℃ |
Storage Temperature | Tstg | -65 | +175 | ℃ |
Collector- Emitter breakdown voltage | V(BR)CEO | IC=3mA | 15 | V |
Collector-Base breakdown voltage | V(BR)CBO | IC=100μA | 20 | V |
Emitter-Base Breakdown Voltage | V(BR)EBO | IE=100 μA | 3 | V |
Forward Current Transfer Ratio | hFE | VCE=6V IC=1mA | 30 | |
Collector-Base Cuttoff Current | ICBO | VCB=15V | ----- 20 | nA |
Collector-Emitter Saturation Voltage | VCE (sat) | IC=5mA IB=0.5mA | ----- 100 | mV |
Characteristic Frequency | fT | VCE=10V IC=4mA | 5000 | Mhz |
Other Requirements
- Chip backside Electrode: Collector
- Chip Backside Metal/material: Au thickness greater thank 1.5μm.
- Chip Frontside Metal/Material: Al Thickness range 1-2 μm.
- Chip Surface Protection: Si3N4 thickness greater than 0.1 μm.
- Chip Appearance sample;
Function detail:
