xps ucf
thx! i've read up on that
but the prob now is.. if i can use ISE's .ucf file in XPS.. izzit the same?
i've actaully tried to add in some codes for pinout in XPS's .ucf file
# VGA port
NET "vga_r" LOC = "R12" ;
NET "vga_g" LOC = "T12" ;
NET "vga_b" LOC = "R11" ;
NET "vga_hs" LOC = "R9" ;
NET "vga_vs" LOC = "T10" ;
# PS2 port
NET "ps2_d" LOC = "M15" ;
NET "ps2_c" LOC = "M16" ;
i found these codes on net.. when i generate the bitstream this is the error msg i've got.
Applying constraints in "system.ucf" to the design...
ERROR:NgdBuild:755 - "system.ucf" Line 126: Could not find net(s) 'vga_r' in the
design. To suppress this error specify the correct net name or remove the
constraint. The 'Allow Unmatched LOC Constraints' ISE property can also be
set ( -aul switch for command line users).
ERROR:NgdBuild:755 - "system.ucf" Line 127: Could not find net(s) 'vga_g' in the
ERROR:NgdBuild:755 - "system.ucf" Line 128: Could not find net(s) 'vga_b' in the
ERROR:NgdBuild:755 - "system.ucf" Line 129: Could not find net(s) 'vga_hs' in
the design. To suppress this error specify the correct net name or remove
the constraint. The 'Allow Unmatched LOC Constraints' ISE property can also
be set ( -aul switch for command line users).
ERROR:NgdBuild:755 - "system.ucf" Line 130: Could not find net(s) 'vga_vs' in
ERROR:NgdBuild:755 - "system.ucf" Line 133: Could not find net(s) 'ps2_d' in the
ERROR:NgdBuild:755 - "system.ucf" Line 134: Could not find net(s) 'ps2_c' in the
ERRORarsers:11 - Encountered unrecognized constraint while parsing.
ERROR:NgdBuild:19 - Errors found while parsing constraint file "system.ucf".
any idea how to solve this?
