phobos1
Full Member level 2
- Joined
- Jan 18, 2010
- Messages
- 135
- Helped
- 15
- Reputation
- 30
- Reaction score
- 15
- Trophy points
- 1,298
- Location
- Salem, Tamil Nadu, India
- Activity points
- 2,112
hi
i have problem with this uart fsm i'm not getting proper output at tx, i am using dcm to generate a 12 mhz clk for generating baud rates. i attached my code below:
module TX_fsm(
input clk,
input rst,
input baudclk,
input go,
input [7:0] data,
output reg TX,
output reg FIN
wire cclk;
BUFG UUT4 (.I(clk),.O(cclk));
parameter IDLE = 4'b0000,
START = 4'b0001,
BUSY = 4'b0010,
STOP1 = 4'b0011,
STOP2 = 4'b0100,
DONE = 4'b0101;
reg [3:0]state, next;
reg [7:0]temp,temp_reg;
reg [3:0]i,i_reg;
always@(posedge cclk, posedge rst)
begin
if (rst)
begin
state <= IDLE;
temp <= 8'd0;
i <= 4'd0;
end
else
begin
state <= next;
temp <= temp_reg;
i <= i_reg;
end
end
always@*
begin
TX = 1'b0;
FIN = 1'b0;
next = 4'bx;
temp_reg = 8'd0;
i_reg = 4'd0;
case (state)
IDLE : begin
TX = 1'b1;
if (!go)
next = IDLE;
else
next = START;
end
START : begin
FIN = 1'b0;
TX = 1'b0;
if (baudclk)
begin
temp_reg[7:0] = data[7:0];
next = BUSY;
end
end
BUSY : begin
TX = temp[7-i];
if (baudclk)
i_reg = i[3:0] + 1'b1;
if (i[3:0] > 4'd7)
next = STOP1;
else
next = BUSY;
end
STOP1 : begin
TX = 1'b1;
if (baudclk)
begin
next = STOP2;
i_reg = 4'd0;
end
end
STOP2 : begin
TX = 1'b1;
if (baudclk)
next = DONE;
end
DONE : begin
TX = 1'b1;
next = IDLE;
FIN = 1'b1;
end
endcase
end
endmodule
module TX_fsm(
input clk,
input rst,
input baudclk,
input go,
input [7:0] data,
output reg TX,
output reg FIN
wire cclk;
START = 4'b0001,
BUSY = 4'b0010,
STOP1 = 4'b0011,
STOP2 = 4'b0100,
DONE = 4'b0101;
reg [3:0]i,i_reg;
begin
if (rst)
begin
state <= IDLE;
temp <= 8'd0;
i <= 4'd0;
end
else
begin
state <= next;
temp <= temp_reg;
i <= i_reg;
end
end
always@*
begin
TX = 1'b0;
FIN = 1'b0;
next = 4'bx;
temp_reg = 8'd0;
i_reg = 4'd0;
case (state)
IDLE : begin
TX = 1'b1;
if (!go)
next = IDLE;
else
next = START;
end
START : begin
FIN = 1'b0;
TX = 1'b0;
if (baudclk)
begin
next = BUSY;
end
end
BUSY : begin
TX = temp[7-i];
if (baudclk)
if (i[3:0] > 4'd7)
next = STOP1;
else
next = BUSY;
end
STOP1 : begin
TX = 1'b1;
if (baudclk)
begin
next = STOP2;
i_reg = 4'd0;
end
end
STOP2 : begin
TX = 1'b1;
if (baudclk)
next = DONE;
end
DONE : begin
TX = 1'b1;
next = IDLE;
FIN = 1'b1;
end
endcase
end
endmodule
