library ieee;
use ieee.std_logic_1164.all;
entity rs232_omo is
generic(clk_max:integer:=10400); --for baudrate
port(
clk : in std_logic;
rst : in std_logic;
start : in std_logic;
input : in std_logic_vector(7 downto 0);
done : out std_logic;
output : out std_logic;
showstates: out std_logic_vector(3 downto 0)
end entity;
architecture dataflow of rs232_omo is
type states is (idle_state,start_state,send_state,stop_state);
signal present_state,next_state : states;
signal data,data_next : std_logic;
begin
process(clk,rst)
variable count : integer range 0 to clk_max;
variable index : integer range 0 to 10;
begin
if rst='1' then
present_state<=idle_state;
count:=0;
data<='1';
elsif rising_edge(clk) then
present_state<=next_state;
count:=count+1;
index:=index+1;
data<=data_next;
end if;
end process;
process(present_state,data,clk,rst,start)
begin
done<='0';
data_next<='1';
case present_state is
when idle_state =>
showstates<="1000";
data_next<='1';
if start='1' and rst='0' then
count:=count+1;
if count=clk_max then
next_state<=start_state;
count:=0;
end if;
end if;
when start_state =>
showstates<="0100";
data_next<='0';
count:=count+1;
next_state<=send_state;
count:=0;
end if;
when send_state =>
showstates<="0010";
count:=count+1;
data_next<=input(index);
if index=7 then
index:=0;
next_state<=stop_state;
else
index:=index+1;
end if;
count:=0;
end if;
when stop_state =>
showstates<="0001";
count:=count+1;
next_state<=idle_state;
done<='1';
count:=0;
end if;
end case;
end process;
output<=data;
end architecture;
