nayakajit87
Member level 5
I am using PIC16F886 to build Interrupt code serial.i Have tested code with pic18F24K40 and its working fine. I have attached code and image for reference. pic18F24k40 uses MPLAB X ide with MCC code configuration. for PIC16F886 it uses MPLAB IDE8.86 code version.I am facing issue in PIC16F886 with receive single byte and transmit single byte of data.
Here is my code for PIC16F886. if i am trying to send any character like 01 it printing 00 instead of 01
PIC18F24K40
#include <htc.h>
#include <stdio.h>
#include<pic.h>
//#include<stdint.h>
#include"delay.h"
#define _XTAL_FREQ 80000000
unsigned int i=0;
unsigned char get_value;
unsigned char c=0;
unsigned char ch;
#define SBIT_TXEN 5
#define SBIT_SPEN 7
#define SBIT_CREN 4
#define LED RC2
#define LED_RX RC7 // Pin assigned RX LED
#define LED_TX RC6 // Pin assigned TX LED
#define DE RC5
#define RECEIVE 0
#define TRANSMIT 1
#define READ_REG 3
#define WRITE_REG 6
#define ILLEGAL_DATAVALUE 0x03
#define FALSE 0
#define TRUE 1
#define METER_ID 1
unsigned short int cnt, num,Dgt=0;
unsigned int j=0;
unsigned char* str;
unsigned int count = 0;
char data = 0;
unsigned char rxbuf[50];
unsigned char ser_data[95];
unsigned char crc_data[95];
unsigned char Max_scroll = 0;
unsigned char buff[10];
//volatile uint8_t index = 0, rec_flag = 0, Delay_count = 0, Id[10], Buffer_count = 0, Cal_count = 0, Disp_count = 0, inc = 0, One_sec_update = 0, Auto_scroll_count = 0;
char data1[10];
unsigned char buf[20];
unsigned int index=0;
unsigned int rec_flag = 0;
//__CONFIG( HS_OSC & WDTE_OFF & PWRTE_ON & CP_OFF & BOREN_ON & LVP_OFF & CPD_OFF & DEBUG_OFF);
__CONFIG( FOSC_HS & WDTE_OFF & PWRTE_ON & CP_OFF & BOREN_ON & LVP_OFF & CPD_OFF & DEBUG_OFF);
void Serial_1_Send_byte(unsigned char trbuf1) {
TXREG=trbuf1;
while(0==TRMT);
char Serial_Receive_byte() {
while(!RCIF);
return RCREG;
void Send_string_uart1(const unsigned char *string) {
unsigned char i=0;
do {
TXREG=string[i++];
while(TXIF==0);
TXIF=0;
} while(string[i]!='\0');
void interrupt isr(void) {
unsigned char ch;
//ch=RCREG;
// Serial_1_Send_byte(ch);
__delay_ms(5);
if((PIE1bits.RCIE==1)&&(PIR1bits.RCIF=1)) {
PIR1bits.RCIF=0;
//Send_string_uart1("UART TEST");
// Send_string_uart1("\n");
//Serial_1_Send_byte(10);
ch=RCREG;
index++;
if(index>=20) {
index=0;
if(index>=8) {
rec_flag = 1;
DE=1;
if(1==RCSTAbits.FERR) {
RCSTAbits.SPEN=0;
RCSTAbits.SPEN=1;
if(1==RCSTAbits.OERR) {
RCSTAbits.CREN=0;
RCSTAbits.CREN=1;
void Serial_1_Init() {
BRG16=1;//1-> 16 bit 0-> 8 bit
SYNC=0; //0->ASYN 1-SYNC
BRGH=1;// 0 for LOW baudrate 1 for High
SPBRG = 207;
RCIDL=1;
TXEN=1;//1->Transmit enable 0-> transmit disble
SPEN=1;//1->enable serial port 0->disable
CREN=1; //1-> enable continous receive 0-> disble receiver
INTCON = 0X00;
TRMT=1;// 1-> Transmit register is empty 0-> full
CCP1IE=1;
RCIE=1;
RCIF=0;
// TXEN=0;//1->Transmit enable 0-> transmit disble
void Timer1_Interrupt() {
INTCON = 0b00000000;
PIE1=0b00000001;
PIR1=0x01;
TMR1H=0xF8;
TMR1L=0xAD;
T1CON=0x31;
void Init_Controller() {
cnt=100;
//OSCCON=0X71;
TRISC = 0x80;
PORTC = 0x80;
TRISB=0X00;
PORTB = 0X00;
TRISA=0x00;
PORTA=0x00;
ADCON0= 0x00;
ANSEL = 0b00000000;
Timer1_Interrupt();
void main(void) {
Init_Controller();
Serial_1_Init();
GIE=1;
PEIE=1;
TMR1IE=1;
while(1) {
PIC18F24K40
#include "mcc_generated_files/mcc.h"
#define LED RC2 // Pin assigned for LED
#define DE RC5
#define RECEIVE 0
#define TRANSMIT 1
#define READ_REG 3
#define WRITE_REG 6
#define FALSE 0
#define TRUE 1
#define METER_ID 1
unsigned int j=0;
unsigned char* str;
char data = 0;
unsigned char rxbuf[50], ser_data[100], crc_data[100], Max_scroll = 0;
char data1[10];
unsigned int k;
void Serial_1_Send_byte(uint8_t trbuf1) {
TX1REG = trbuf1;
while (0 == PIR3bits.TXIF);
//while (!TX1IF);
unsigned char i = 0;
do {
TX1REG = string[i++];
while (0 == TX1STAbits.TRMT);
} while (string[i] != '\0');
while(0==PIR3bits.RCIF);
return RC1REG;
char usart_RxString() {
while(*str !='\0') {
// while not end of string
RCREG = *str; // read next character
str++; // increment pointer to next character
return RC1REG; // return the contents of uart
void UART_ISR() {
if((PIE3bits.RCIE==1)&&(PIR3bits.RCIF=1)) {
PIR3bits.RCIF=0;
rxbuf[index] = Serial_Receive_byte();
Serial_1_Send_byte(rxbuf[index]);
index++;
if(index>=20) {
index=0;
if(index>=8) {
rec_flag = 1;
DE=1;
if(1==RCSTA1bits.FERR) {
RCSTA1bits.SPEN=0;
RCSTA1bits.SPEN=1;
if(1==RCSTA1bits.OERR) {
RCSTA1bits.CREN=0;
RCSTA1bits.CREN=1;
void main(void) {
// Initialize the device
SYSTEM_Initialize();
while (1)
__delay_ms(100);
