vinay bs
Member level 3
hi folks,
I am facing problem wen i club UART and I2C together in my compiler. I am using mikroC Compiler and PIC16f883 microchip IC. I2C is used for reading the time from DS1307 IC and displaying it on LCD, UART used for serial communication to send the data (PC Hyper terminal).
It works good wen i compile individually I2C and UART but not together, and i am using mikroc inbuilt routines to read and write both i2c and uart.
Please help me out on this...
Below is my code
Below is my code
// LCD module connections
sbit LCD_RS at RB2_bit;
sbit LCD_EN at RB3_bit;
sbit LCD_D4 at RB4_bit;
sbit LCD_D5 at RB5_bit;
sbit LCD_D6 at RB6_bit;
sbit LCD_D7 at RB7_bit;
sbit LCD_RS_Direction at TRISB2_bit;
sbit LCD_EN_Direction at TRISB3_bit;
sbit LCD_D4_Direction at TRISB4_bit;
sbit LCD_D5_Direction at TRISB5_bit;
sbit LCD_D6_Direction at TRISB6_bit;
sbit LCD_D7_Direction at TRISB7_bit;
// End LCD module connections
unsigned short read_ds1307(unsigned short address)
unsigned short r_data;
I2C1_Start();
I2C1_Wr(0xD0); //address 0x68 followed by direction bit (0 for write, 1 for read) 0x68 followed by 0 --> 0xD0
I2C1_Wr(address);
I2C1_Repeated_Start();
I2C1_Wr(0xD1); //0x68 followed by 1 --> 0xD1
r_data=I2C1_Rd(0);
I2C1_Stop();
return(r_data);
void write_ds1307(unsigned short address,unsigned short w_data)
I2C1_Start(); // issue I2C start signal
I2C1_Wr(0xD0); // send byte via I2C (device address + W)
I2C1_Wr(address); // send byte (address of DS1307 location)
I2C1_Wr(w_data); // send data (data to be written)
I2C1_Stop(); // issue I2C stop signal
unsigned char BCD2UpperCh(unsigned char bcd)
return ((bcd >> 4) + '0');
unsigned char BCD2LowerCh(unsigned char bcd)
return ((bcd & 0x0F) + '0');
void space_fun(unsigned char x)
char j;
for(j=0;j<x;j++)
UART1_Write(32);
int second;
int minute;
int hour;
int hr;
int day;
int dday;
int month;
int year;
int d_rec;
unsigned short set_count = 0;
short set;
char time[] = "00:00:00";
char date[] = "00-00-2000";
char i;
char a = 0;
void main()
I2C1_Init(100000); //DS1307 I2C is running at 100KHz
UART1_Init(2400); // Initialize UART module at 9600 bps
Delay_ms(50); // Wait for UART module to stabilize
C1ON_bit = 0; // To turn off comparators
C2ON_bit = 0;
ADCON0 = 0x80; // To turn off analog to digital converters
ANSEL = 0x00;
ANSELH = 0x00;
TRISB = 0x00;
TRISA = 0x2F;
TRISC = 0x00;
PORTA = 0x00;
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
Lcd_out(1,1,"Time:");
Lcd_out(2,1,"Date:");
write_ds1307(6, 0x12); // write year
UART1_Write_text("To Set Time and Date");
UART1_Write(13);
UART1_Write_text("Press 5 to Set");
UART1_Write(13);
UART1_Write_text("Press 8 to increase");
UART1_Write(13);
UART1_Write_text("Press 2 to decrease");
UART1_Write(13);
while(1)
if(UART1_Data_Ready()==1)
d_rec = UART1_Read();
UART1_Write(d_rec);
set = 0;
if(d_rec == 53) //set
//UART1_Write_text("set button pressed");
set_count++;
if(set_count == 1)
Lcd_cmd(_LCD_FIRST_ROW);
for(i=0;i<5;i++)
Lcd_Cmd(_LCD_MOVE_CURSOR_RIGHT);
Lcd_Cmd(_LCD_BLINK_CURSOR_ON);
Delay_ms(1000);
if(set_count == 2)
for(i=0;i<8;i++)
Delay_ms(1000);
if(set_count == 3)
for(i=0;i<11;i++)
Delay_ms(1000);
if(set_count == 4)
Lcd_cmd(_LCD_SECOND_ROW);
for(i=0;i<5;i++)
Delay_ms(1000);
if(set_count == 5)
for(i=0;i<8;i++)
Delay_ms(1000);
if(set_count == 6)
for(i=0;i<13;i++)
Delay_ms(1000);
if(set_count >= 7)
set_count = 0;
d_rec = 0;
if(set_count)
if(d_rec == 56)
//UART1_Write_text("increment");
set = 1;
d_rec = 0;
if(d_rec == 50)
//UART1_Write_text("decrement");
set = -1;
d_rec = 0;
if(set_count && set)
switch(set_count)
case 1:
hour = BCD2Dec(hour);
hour = hour + set;
hour = Dec2BCD(hour);
if(hour > 0x23)
hour = 0x00;
else if(hour < 0x00)
hour = 0x23;
write_ds1307(2, hour); //write hour
break;
case 2:
minute = BCD2Dec(minute);
minute = minute + set;
if(minute >= 60)
minute = 0;
if(minute < 0)
minute = 59;
minute = Dec2BCD(minute);
write_ds1307(1, minute); //write min
break;
case 3:
if(abs(set))
write_ds1307(0,0x00); //Reset second to 0 sec. and start Oscillator
break;
case 4:
day = BCD2Dec(day);
day = day + set;
day = Dec2BCD(day);
if(day >= 0x32)
day = 1;
if(day <= 0)
day = 0x31;
write_ds1307(4, day); // write date
break;
case 5:
month = BCD2Dec(month);
month = month + set;
month = Dec2BCD(month);
if(month > 0x12)
month = 1;
if(month <= 0)
month = 0x12;
write_ds1307(5,month); // write month
break;
case 6:
year = BCD2Dec(year);
year = year + set;
year = Dec2BCD(year);
if(year < 0x00)
year = 0x99;
if(year >= 0x99)
year = 0;
write_ds1307(6, year); // write year
break;
second = read_ds1307(0);
minute = read_ds1307(1);
hour = read_ds1307(2);
day = read_ds1307(4);
month = read_ds1307(5);
year = read_ds1307(6);
time[0] = BCD2UpperCh(hour);
time[1] = BCD2LowerCh(hour);
time[3] = BCD2UpperCh(minute);
time[4] = BCD2LowerCh(minute);
time[6] = BCD2UpperCh(second);
time[7] = BCD2LowerCh(second);
date[0] = BCD2UpperCh(day);
date[1] = BCD2LowerCh(day);
date[3] = BCD2UpperCh(month);
date[4] = BCD2LowerCh(month);
date[8] = BCD2UpperCh(year);
date[9] = BCD2LowerCh(year);
if(a == 0)
a++;
UART1_Write_text("Time :");
space_fun(1);
UART1_Write(time[0]);
UART1_Write(time[1]);
UART1_Write(58);
UART1_Write(time[3]);
UART1_Write(time[4]);
UART1_Write(58);
UART1_Write(time[6]);
UART1_Write(time[7]);
UART1_Write(13);
UART1_Write_text("Date :");
space_fun(1);
UART1_Write(date[0]);
UART1_Write(date[1]);
UART1_Write(58);
UART1_Write(date[3]);
UART1_Write(58);
UART1_Write(date[8]);
UART1_Write(date[9]);
UART1_Write(13);
Lcd_out(1, 6, time);
Lcd_out(2, 6, date);
Delay_ms(50);
