two weired error in a c programin keil
dizgah
Member level 5
Member level 5
iran-8par
hi every body
i declared a void function
void SPI_MFRC522_Init(void)
& used it in a main program
void RC522_IO_Init(void)
	GPIO_InitTypeDef GPIO_InitStruct;
	RCC_APB2PeriphClockCmd(RC522_RESET_GPIO_CLK,ENABLE);
	GPIO_InitStruct.GPIO_Pin = RC522_RESET_PIN;
	GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP;
	GPIO_Init(RC522_RESET_GPIO_PORT, &GPIO_InitStruct);
[B][COLOR="#FF0000"]	SPI_MFRC522_Init(void);[/COLOR][/B]
and keil shows me this 2 error:
#29:expected an expression
#140:too many arguments in function call
hi every body
There is actually nothing weird about the error message.
When a function/routine's parameter list is defined as "void," you must call the function/routine with an empty parameter list, instead of the keyword "void."
Instead of:
	[COLOR="#FF0000"]SPI_MFRC522_Init(void);[/COLOR]
Try:
	[COLOR="#FF0000"]SPI_MFRC522_Init();[/COLOR]
BigDog
Reactions: dizgah
    dizgah
really thanks
then when we set void for input argument of function?
whats difference ?
WBR
whats difference ?
I'm not sure I understand your question. Can you provide an example code snippet as to what you are referring?
void routine(void)
In defining the above routine, the first void in green indicates the routine does not return a value of any type.
The second void in blue, indicates the routine neither expects nor accepts a parameter of any type to be passed.
One of the only other uses of the keyword void is to define a pointer of type void, essentially a generic pointer type.
If you would provide some examples specific to your question, I should be able to elaborate on the specifics of the situation.
BigDog
Reactions: dizgah
    dizgah
