Two ways to implement connectivity on an embedded system
FSio
Junior Member level 3
ppp source code embedded
If you require to connect to a ISP through POTs (dial-up), then require PPP,IP,TCP......
If you require to connect to a ISP trrough xDSL, then requiere ETHERNET,IP;TCP.......
There are 2 ways to implement connectivity on a embedded system:
- Libs or code running into uC or uP.
- Stack TCP/IP (is a IC that resolves TCP/IP by mean of APIs)
According to my experience,
To the option Stack TCP/IP see:
---AD561-D/20 (c-o-n-n-e-c-t-o-n-e, has 2 choice LAN and/or DIAL-UP )
To the option LIbs or code
---Rabbit3000
pisoiu
Advanced Member level 3
Romania
Re: ppp/eth to embedded
You can also implement both ppp/lcp/ipcp/ip/udp/tcp/http or ethernet/arp/icmp/tcp/udp/smtp on scenix (ubicom) microcontrollers. I can provide source code examples for this if you need.
wolf69
or you can use linux embedded that has it all..
Bye!
FSio
wolf69,
You said tools to embedded on Linux,
which tools are? and What uC o uP support these tools?
